> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/d5-lite/lite-user-manual/camera-controls-revit.md).
# Camera Controls · Revit
In the Lite render viewport you can move and look around the model freely. Shortcut hints in the lower-left corner show the available controls at any time.<br>
### Moving the Camera
| Action                             | Shortcut                         |
| Move forward / back / left / right | W / A / S / D                    |
| Rise / descend                     | Q / E                            |
| Speed up                           | Shift + movement key             |
| Slow down                          | Space + movement key             |
| Move forward / back                | Scroll wheel                     |
| Adjust movement speed              | Hold right mouse button + scroll |
| Adjust field of view (FOV)         | Alt + scroll                     |
### Rotate and Pan
| Action                              | Mouse                        |
| Orbit (rotate around the target)    | Shift + middle button        |
| Look around (from a fixed position) | Hold the right mouse button  |
| Pan                                 | Hold the middle mouse button |
### Perspective and Orthographic
| Action                        | Shortcut |
| Perspective / orthographic    | P        |
| Two-point perspective         | F8       |
| Align to Revit's current view | 0        |
After turning off Sync Viewport, press 0 to align the Lite viewport with Revit's current view.
