Camera Controls · Rhino
In the Lite render viewport you can move and look around the model freely. Shortcut hints in the lower-left corner show the available controls at any time.
Moving the Camera
Action
Shortcut
Move forward / back / left / right
W / A / S / D
Rise / descend
Q / E
Speed up
Shift + movement key
Slow down
Space + movement key
Move forward / back
Scroll wheel
Adjust movement speed
Hold right mouse button + scroll
Adjust field of view (FOV)
Alt + scroll
Rotate and Pan
Action
Mouse
Orbit (rotate around the target)
Hold the right mouse button
Look around (from a fixed position)
Hold the left mouse button
Pan
Hold the middle mouse button
Perspective and Orthographic
Action
Shortcut
Perspective / orthographic
P
Two-point perspective
F8
Align to Rhino's current view
0
After turning off Sync Viewport, press 0 to align the Lite viewport with Rhino's current view.When using Rhino Named Views, first switch to the desired view in Rhino; with Sync Viewport on, Lite follows automatically. With Sync Viewport off, press 0 to align manually.
Last updated
