> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/d5-lite/lite-user-manual/d5-render-sync.md).
# D5 Render Sync
<figure><img src="/files/S4c1ECbTKcVILRDAaPS1" alt=""><figcaption></figcaption></figure>
#### Known Issues
1. Environment（HDRI） & Effect Parameter is not yet supported for synchronization to the D5 Render scene list.
2. The .d5a export currently does not include proxy assets.
# Agent Instructions
This documentation is published with GitBook. GitBook is the documentation platform designed so that both humans and AI agents can read, navigate, and reason over technical content effectively. Learn more at gitbook.com.
## Querying This Documentation
If you need additional information that is not directly available in this page, you can query the documentation dynamically by asking a question.
Perform an HTTP GET request on the current page URL with the `ask` query parameter, and the optional `goal` query parameter:
GET https://docs.d5render.com/d5-lite/lite-user-manual/d5-render-sync.md?ask=<question>&goal=<endgoal>
Use this mechanism when the answer is not explicitly present in the current page, you need clarification or additional context, or you want to retrieve related documentation sections.
