> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/d5-lite/lite-user-manual/lights-revit.md).
# Lights · Revit
In Revit, D5 Lite reads the lights from native Lighting Fixture families and provides an independent light panel in the Lite toolbar for adjusting light rendering. After you place a Lighting Fixture in Revit, Lite automatically recognizes its light type and displays adjustable parameters in the light panel.
### Light Types
Lite automatically maps the light shape in Revit Lighting Fixture families to five Lite light types: Point Light, Spot Light, Strip Light, Rectangle Light, and Disc Light. On first recognition, Lite reads the initial intensity, color, and color temperature from the Revit light; after that, light parameters are adjusted independently in Lite's light panel and do not write back to Revit.
### Adjustable Parameters
Click the light button in the Lite toolbar to open the light panel. After selecting a Lighting Fixture in the Revit viewport, the light panel shows its corresponding Lite light parameters. Adjustable parameters include: intensity, color or color temperature (toggle between the two); Spot Lights also support cone angle adjustment. Light position and orientation are still controlled in Revit by moving or rotating the fixture instance; Lite updates in real time with the sync.
### Sync to D5 Render
Revit lights can move into D5 Render via Live Sync for further refinement.
