Lights · Rhino
Last updated
In Rhino, D5 Lite reads native Rhino lights and does not provide a separate Lite light panel. You continue to create and edit lights in Rhino; Lite reads them and shows the corresponding render result.
Point Light
Point Light
Spotlight
Spot Light
Linear light
Strip Light
Rectangular light
Rectangle Light
Rhino's directional (parallel) light is not read as a Lite light.
Lite reads the position, orientation, color, intensity, angle, and size of Rhino lights; the Spot Light direction follows the light direction in Rhino. After you adjust a light in Rhino, the Lite render updates with the sync.
Rhino lights can move into D5 Render via Live Sync for further refinement.
Last updated
