> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/d5-lite/lite-user-manual/lights-rhino.md).
# Lights · Rhino
In Rhino, D5 Lite reads native Rhino lights and does not provide a separate Lite light panel. You continue to create and edit lights in Rhino; Lite reads them and shows the corresponding render result.
### Light Types
| Rhino light       | Lite render result |
| Point Light       | Point Light        |
| Spotlight         | Spot Light         |
| Linear light      | Strip Light        |
| Rectangular light | Rectangle Light    |
Rhino's directional (parallel) light is not read as a Lite light.
### Reading and Editing
Lite reads the position, orientation, color, intensity, angle, and size of Rhino lights; the Spot Light direction follows the light direction in Rhino. After you adjust a light in Rhino, the Lite render updates with the sync.<br>
### Sync to D5 Render
Rhino lights can move into D5 Render via Live Sync for further refinement.
