Other Features
Window and Panels
  • The Lite window stays on top of the modeling software by default; pinning can be turned off. Shortcut: Shift + Alt + T.
  • F9: hide or show all panels in the window so the image fills it.
  • Panels such as Environment and Effects can be dragged, and can be detached to float beside the main window; the main window and most panels can be resized freely.
Undo and Redo
  • Ctrl + Z to undo, Ctrl + Y to redo.
  • Right-click a material parameter to reset it to the template default.
Shortcut Hints
The window always shows shortcut hints and live status (FOV, movement speed, FPS); you can turn this on or off in Settings.
Account & Sign-in
Sign in through the D5 Launcher to use Lite; your account and entitlements are shared with D5 Render.
Last updated
