> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/d5-lite/lite-user-manual/other-features.md).
# Other Features
### Window and Panels
* The Lite window stays on top of the modeling software by default. Click the pin button in the title bar or press Shift + Alt + T to toggle it; both control the same state, and the state is kept the next time you start Lite. When you switch to another application, Lite does not sit on top of it; returning to the modeling software or Lite restores the original stacking order.
* F9: hide or show all panels in the window so the image fills it.
* Panels such as Environment and Effects can be dragged, and can be detached to float beside the main window.
### Undo and Redo
* Ctrl + Z to undo, Ctrl + Y to redo.
* Right-click a material parameter to reset it to the template default.
### Shortcut Hints
The window always shows shortcut hints and live status (FOV, movement speed, FPS); you can turn this on or off in Settings.
<figure><img src="/files/P16gYJbHGjpRAGBuEWz6" alt="" width="342"><figcaption></figcaption></figure>
### Account & Sign-in
Sign in through the D5 Launcher to use Lite; your account and entitlements are shared with D5 Render.
