Render Settings & Output
D5 Lite renders the current view to an image. Before rendering, set the image quality, format, and aspect ratio.
Quality and Format
Setting
Notes
Standard
Up to 2K on the longest edge; good for quick previews and everyday communication.
High
Up to 4K on the longest edge; for images that need more detail.
PNG
Default format; better image quality.
JPG
For smaller file size.
Aspect Ratio
Choose Fill Window, Follow Modeling Software Window, or a common fixed ratio: 16:9, 9:16, 3:2, 2:3, 4:3, 3:4, 1:1.
Rendering
  1. Frame the view you want to render.
  2. Open the render settings and choose quality, format, and aspect ratio.
  3. Click the render button in the lower-right corner.
  4. Choose a save location and rename the file if needed.
  5. Wait for rendering to finish. Progress and an estimated time are shown, and you can cancel.
  6. When done, you can open the folder containing the image.
The file type follows the format chosen before rendering. The save path remembers your last location; a new project returns to the default.
Last updated
