Microsoft Azure SSO Login
SSO feature requires a whitelist for activation and is intended for enterprise clients.
Note:
To activate this feature, please get in touch with the relevant sales representative or customer success manager (sales@d5techs.com), and provide the team owner's account.
Microsoft Azure SSO (SAML) Setup Guide
1. Prerequisites
The user must have a Microsoft Azure account for their company
After logging in, go to the “Enterprise Applications” page
2. Create an Application
Click “Create your own application”
Give your application a name
Choose “Set up single sign-on” and select SAML as the login method
3. Permission Requirements
Only Team Owners or Super Team Admins have access to the SSO configuration page
4. SSO Configuration Details
1. Enable SSO
SSO is disabled by default
2. Configuration Item Details
✅ Identity Provider (IdP)
Currently, only Microsoft Entra is supported
✅ SSO Protocol
Currently, only SAML is supported
✅Login Method Options
There are two options for how users log in:
Single Sign-On (SSO) & Username/Password (default)
Users can log in using either SSO or their account credentials.
SSO Only
Users can only log in via Single Sign-On; password login will be disabled.
✅Add Domain(s)
Enter your company email suffixes (e.g.,
yourcompany.com)Multiple domains can be added
✅ Service Provider (SP) Configuration
Recommended method:
a. Download the XML file from the D5 Team Management backend
b. In the Azure portal, open the SSO configuration module and go to “Set up Single Sign-On”
c. Click “Upload metadata file” and import the downloaded XML file
Manual method:
a. In Azure’s “Basic SAML Configuration” section, manually fill in the following:
- Copy the Identifier (Entity ID) from the D5 backend and paste it into the corresponding field
- Copy the Assertion Consumer Service URL (ACS URL) and paste it accordingly
b. Click “Save” to apply
✅ Identity Provider (IdP) Information
In the Azure portal’s SSO module, go to the “Set up Single Sign-On” section
Under the SAML Certificates area, download the “Federation Metadata XML”
Upload this file to the D5 Team Management backend
The system will parse the content and automatically fill in the IdP login URL
Microsoft Azure SCIM Configuration Guide
1. Setup in D5 Myspace - Team Management Backend
Enable Provisioning
2. Setup in Microsoft Azure
Go to Enterprise Applications > SSO Control Module > Provisioning
Click Add a new configuration
Enter the SCIM endpoint and access token provided in the D5 Team Management Backend. Click Test Connection, and after the test is successful, click Create.
Click Settings, enable the provisioning switch, and click Save.
💡 If the access token changes in the future:
Navigate to Provisioning > Settings > Admin Credentials
Set the Provisioning Status to On
Click Save
Finally, enable provisioning to sync user accounts
Click Mappings, then select Provision Microsoft Entra ID Users.
On the attribute mapping page, click Add New Mapping.
Configure the new mapping with the following steps. After completing the configuration, click Save:
Set Mapping type to Expression
Enter the following Expression:
SingleAppRoleAssignment([appRoleAssignments])Set Target attribute to
roles[primary eq "True"].valueSet Match objects using this attribute to Yes
Set Matching precedence to 2
Return to the attribute mapping page and click Save.
Return to the Overview (Preview) page to confirm whether provisioning has started. If it hasn't, click Start Provisioning.
3. Creating Application Roles
Go to Enterprise Applications > SSO Control Module > Properties
Click “App Registrations”
After entering, go to the “App Roles” section
You can add new roles here as needed
⚠️ If no roles are configured, synced users will default to Team Member role
4. Start provisioning
5. SCIM Sync Behavior
When SCIM is enabled, the following features will be disabled in the D5 Team Management Backend:
Manually editing team member roles
Modifying member account attributes
Inviting users to the team
Removing members from the team
In Group Management, the following options will also be hidden:
Invite to Team
Remove from Team
Sync Status and Frequency
Sync Frequency: Once every 40 minutes
View Sync Results:
In the Azure backend, click on sync logs
You can see each step of the sync and any failure reasons
Example Case
A new user is added in the IdP (who has never registered in D5)
After waiting for the sync cycle, the user will automatically appear in the team
6. Sync Failure Scenarios
Team Seat Limit Reached
If an existing D5 account is being synced while the team's seat quota is full, the sync will fail, and the account will not be added to the team.
Backend Deployment in Progress
If the D5 backend is undergoing a release during the sync process,the sync will fail.
The account will not be created nor added to the team.
It will be retried in the next scheduled sync.
Last updated
