Okta SSO Login
SSO feature requires a whitelist for activation and is intended for enterprise clients.
Note:
To activate this feature, please get in touch with the relevant sales representative or customer success manager (sales@d5techs.com), and provide the team owner's account.
Prerequisites
  • An account with Okta administrator privileges is required.
  • In DirectoryGroups, create the following three groups (names must match exactly):
    • d5-superAdmin
    • d5-admin
    • d5-member
User roles within the team will be assigned based on the group they belong to.
Configure SAML in Okta
  1. Go to ApplicationsApplications and create a new application.
  1. Select SAML 2.0 as the sign-in method.
  1. Enter the Application Name, check “Do not display application icon to users”, then click Next.
  1. Copy the URL and Entity ID from the D5-Myspace admin backend and paste them into the corresponding SAML configuration fields in Okta.
  • Name ID format: EmailAddress
  • Application username: Okta username
D5-Myspace-TeamDashboard
Okta
  1. Click Next, then click Finish on the feedback page.
Okta → D5-Myspace Team Management Backend
  1. Open the application’s Sign On page in Okta.
  1. Click Copy, open a new browser tab, paste the URL, and visit it.Right-click the page and save it as metadata.xml.
  1. Upload metadata.xml to the D5-Myspace Team Management Backend.
Configure SCIM in Okta
  1. Go to GeneralEdit.
  1. Under Provisioning, select SCIM and click Save.
Provisioning Settings
In ProvisioningEdit, update the following settings and save:
  • SCIM connector base URL Copy from: D5-Myspace Team Admin → SSO & Provisioning → Provisioning Management → SCIM Endpoint
  • Unique identifier field for users userName
  • Supported provisioning actions Enable the first four options
  • Authentication Mode HTTP Header
  • Authorization Copy the Access Token from: D5-Myspace Team Admin → SSO & Provisioning → Provisioning Management
  • To App Click Edit, enable the first three options, and save.
  • D5-SSO Attribute Mappings Keep only the required mappings and delete the rest.
Push Groups
  • Go to Push Groups and add the following three groups:
    • d5-superAdmin
    • d5-admin
    • d5-member
Assignments
  • Go to Assignments and add the users who will log in via SSO.
D5-Myspace SSO Configuration
Access Control
  • The configuration page is visible only if:
    • The team is on the whitelist, and
    • The logged-in user is the team owner or a super admin
    • SSO is disabled by default.
Whitelist Behavior
  • If SSO & SCIM are enabled and the team is removed from the whitelist:
    • All SSO & SCIM settings are automatically disabled.
  • After re-adding the team to the whitelist:
    • Users must manually re-enable SSO & SCIM.
Configuration Options Explained
  • Identity Provider
    • Microsoft Entra (default)
    • Okta
  • SSO Protocol
    • Currently supports SAML only
  • Login Method
    • SSO + Username/Password (default)
    • SSO Only
  • Domain
    • Required
    • Leading/trailing spaces are trimmed
    • Domain format validation enabled
    • Max length: 128 characters
    • Domain is saved immediately; domain list may be empty
Service Provider (SP) Information
  • These values are fixed
  • Users must manually copy them into the corresponding fields in Okta
Identity Provider (IdP) Information
  • Upload the metadata.xml exported from Okta
  • The system will parse it and automatically extract the IdP Login URL
D5-Myspace SCIM Configuration
After SAML is successfully configured:
  1. Enable Provisioning Management in the D5-Myspace team admin.
  2. The system automatically generates:
    • SCIM Endpoint
    • Access Token
  3. Copy both values into Okta to complete the integration.
SSO Login Logic & Role Assignment
Account Creation
  • If the user does not exist in D5:
    • Create the account and add it to the team
  • If the user already exists:
    • Add directly to the team
Role Mapping Rules
  • No Okta group assigned → role = Member
  • Assigned to d5-superAdmin
    • If no super admin exists → role = Super Admin
    • If one already exists → role = Member
  • Assigned to d5-admin → role = Admin
  • Assigned to d5-member → role = Member
  • Assigned to multiple groups → role = Member
  • Owner’s role never changes, regardless of group
  • Removing a user in Okta → SSO login fails; D5 data unchanged
  • Changing Okta group → role does not change on SSO login
  • Seat limit reached → SSO login fails until seats are increased
Web Login
Enabled SSO
  • MySpace validates:
    • Email format
    • Email domain
  • Email validity is handled by Okta
    Login methods:
    • Password, phone, WeChat, Gmail logins still work
    SSO Only
    • Personal login still works
    • Switching to Team identity shows an error
    • Owner is not affected
    Disabled SSO
    • Login fails with error: “SSO-SAML is disabled”
Client Login (D5 Render)
  1. Enter company email and click Next
  2. After Okta authentication:
    • Redirect to an intermediate page
    • Click Open D5 Render
  3. Login completes successfully
Edge cases:
  • Empty input → Next button disabled
  • Unconfigured domain → “SSO login is not configured for this account”
  • “Management only” accounts:
    • SSO succeeds
    • User cannot access Showreel features
    • Token is cleared → appears logged out in client
SCIM Synchronization
  • Triggered by events
  • Sync completes within ~5 minutes
SCIM Scenarios
Assignments changes
  • Removing a user in Okta → user removed from D5 team (except owner)
  • Assigning user:
    • No group → Member
    • With group → role based on group
    • Existing admin → role unchanged unless overridden by group
Group changes
  • Removed from all groups → role becomes Member
  • Changed to d5-superAdmin
    • If no super admin exists → Super Admin
    • Otherwise → role unchanged
  • Multiple groups → role determined by last added group
  • Owner role never changes
SCIM Restrictions
When SCIM is enabled:
  • Disable in D5 backend:
    • Manual role changes
    • Account attribute changes
    • Invite to team
    • Remove from team
  • Same restrictions apply in Group Management
Seat Limit
  • If seats are full:
    • SCIM sync fails in Okta
  • After adding seats:
    • Admin must remove failed users from Assignments
    • Re-add them to trigger sync again
Last updated
