Corona Function Support Table
Corona | 3ds Max
CoronaPhysicalMtl
UI
Name
Support
Note
Metalness
Yes
Base Color
Yes
Roughness
Yes
IOR
No
This parameter is not supported, but can be converted into an equivalent highlight intensity value
edge color
No
Bump
Partial Support
Supports bump mapping, but does not support procedurally generated bumps.
Anisotropy
No
Translucency
No
Refraction
Partial Support
Caustics
No
Thin absorption
No
Opacity
Partial Support
Displacement
Partial Support
Clearcoat Layer
Yes
Sheen Layer
Yes
Volumetric Absorption
No
Volumetric Scattering
No
SSS
Partial Support
Self-illumination
Yes
Override
No
CoronaLegacyMtl
UI
Name
Support
Note
Diffuse
Yes
Translucency
No
Reflection Color
Yes
IOR
No
Reflection Glossiness
Yes
Reflection Anisotropy
No
Refraction Color
Yes
Refraction IOR
Yes
Refraction Glossiness
No
Dispersion
No
Opacity
Partial Support
Bump
Partial Support
Displacement
Partial Support
No
No
SSS
Partial Support
Self-illumination
Yes
Override
No
Other Materials
Name
Support
Note
CoronaLayeredMtl
Yes
CoronaRaySwitchMtl
Yes
CoronaShadowCatcherMtl
No
CoronaSkinMtl
No
will enable Subsurface template and sync the SkinColor and SkinColor maps
CoronaHairMtl
No
CoronaSlicerMtl
No
CoronaScannedMtl
No
CoronaUnsupportedMtl
No
CoronaSelect Material
Yes
CoronaLightMtl
Yes
Bump
Name
Support
Note
Bump
Partial Support
Procedurally generated bump maps are not supported, intensity needs to be aligned
Normal
Partial Support
Displacement
Name
Support
Note
Normal Displacement
Partial Support
Currently D5 does not support displacement of model deformation, only displacement of visual effects.
Vector Displacement
No
Per-face normal
No
Per-face vector/mixed
No
Water level
No
Geometry
Name
Support
Note
mesh
Yes
Hair and Fur
No
Proxy Object
No
Decal
No
bend
No
Include/exclude
No
Corona Pattern modifier
No
Chaos Scatter
No
VolumeGrid
No
Light
Name
Support
Note
Sphere Light
Yes
Rect Light
Yes
Point Light
Yes
Disc Light
Yes
Light material
Partial Support
transfer to D5's emissive material
Mesh Light
Partial Support
Spotlight
Yes
ies
Yes
Camera
Name
Support
Note
Perspective Camera
Yes
Orthographic Camera
Yes
Perspective Camera
No
Spherical, Fisheye, Cylindrical Camera
No
Depth of Field
Partial Support
Resolution, Aspect Ratio
Yes
Far/Near Clip
No
Only supports Near Clip
Multiple Camera Export
No
Environment
Name
Support
Note
Monochromatic environment
No
Environment Map
Partial Support
Supports HDRI, Bitmap
corona geo sky
No
Clouds
No
Airplane Contrail
No
Volume Effect
No
Multiple Ambient Lights
No
Corona Sun
No
Global volume
No
Map
Name
Support
Note
Bitmap
Partial Support
Color
Yes
Color Correction
Yes
CoronaData
Partial Support
CheckerMap
Yes
CoronaFrontBack
Yes
Gradient
Yes
MaxFalloffMap
Partial Support
CoronaMix
Yes
CoronaMultiMap
Yes
CoronaMappingRandomizer
Yes
CoronaTriplanar
Yes
CoronaSelect
Yes
CoronaNormal
Yes
Bitmap
Yes
Checker
Yes
ColorCorrection
Yes
Falloff
Partial Support
Gradient
Yes
Mix
Yes
Normal Bump
Yes
Output
Partial Support
Noise
Yes
RgbMultiply
Yes
Curvature
No
Chamfer
Yes
Last updated
