# Page Not Found
The URL `user-guide/common-pop-up-windows/why-prompt-lights-cannot-exceed-1024` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Why prompt 'Lights cannot exceed 4096'?](https://docs.d5render.com/user-guide/common-pop-up-windows/why-prompt-lights-cannot-exceed-4096.md)
- [Why prompt 'The number of caustic lights cannot exceed 64'?](https://docs.d5render.com/user-guide/common-pop-up-windows/why-prompt-the-number-of-caustic-lights-cannot-exceed-64.md)
- [Why prompt 'The material of model cannot be reused'?](https://docs.d5render.com/user-guide/common-pop-up-windows/why-prompt-the-material-of-model-cannot-be-reused.md)
- [Why prompt 'Save Failed' when saving a file?](https://docs.d5render.com/user-guide/common-pop-up-windows/why-prompt-save-failed-when-saving-a-file.md)
- [Why prompt 'DX12 is not supported on your system. '?](https://docs.d5render.com/user-guide/common-pop-up-windows/why-prompt-dx12-is-not-supported-on-your-system..md)
GET https://docs.d5render.com/user-guide/common-pop-up-windows/why-prompt-lights-cannot-exceed-4096.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/user-guide/common-pop-up-windows/why-prompt-lights-cannot-exceed-4096.md`).
