Launching D5 from the D5 converter gives the error "default error".
Key words: Import model | File format | Workflow
When the D5 client detects an abnormality in the network connection of the current device, it will prompt "default error".
Solution: Disable the firewall and the VPN, then sync again.
Last updated
