> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/user-guide/material/what-materials-are-the-flowing-water-templates-suitable-for-what-are-the-special-parameters.md).
# What materials are the Flowing water templates suitable for? What are the special parameters?
Flowing water template automatically generates flowing water animation based on base colour/base colour mapping to better simulate waterfalls, running water, streams and etc. materials.
<div align="left"><figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2Ftd8Mm2JroLFG0QOxfdp2%2Fflowing%20water.gif?alt=media&amp;token=b3c094c0-394b-4c3b-894b-fab29df0e32c" alt=""><figcaption></figcaption></figure></div>
Flowing Water Material has 5 different templates. In addition to color, normal, specular, and transparency, support for adjusting the foam, flow velocity, offset parameters.
The UV module controls the flow direction and normal texture tiling of the water body, and when UV scaling is performed, the foam and normal bump effects will scale together.
> **The effect of the flowing water material is affected by the model's texture map and UVs.**&#x20;
> The UVs of the model itself should be continuous and square 1:1 maps are preferred.
