What is the correct naming convention when importing PBR maps with one click?
The PBR material system contains two sets of workflows, the metallic/roughness system and the specularity/glossiness system, which D5 supports belongs to the metallic/roughness workflow. The texture imported by the user should conform to the suffix naming rules of this workflow in order to correctly identify the material effect.
The Metallic/Roughness workflow mapping suffix naming and mapping slot corresponding rules are as follows:
  • [ Base color ] slot:_color(_col) /_base color /_basecolor /_albedo
  • [ Specular ] slot:_specularLevel
  • [ Metallic ] slot:_metallic / _ metalness
  • [ Normal ] slot:_normal(_nrm) /_bump
  • [ roughness ] slot:_roughness(_rough)
  • [ AO ] slot: _ambient occlusion(_ao)
  • [ Opacity] slot:_opacity
  • [ Height ] slot:_displacement(_disp)/_height
Other mapping suffixes may cause incorrect effects or failure to import, so please correct them yourself. Among them, the normal mapping format used by D5 is Direct X.
Last updated
