> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/user-guide/material/how-to-select-material-in-the-scene.md).
# How to select material in the scene?
<div align="left"><figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FREkYkgvcxbdSHnCP4C0q%2Fimage.png?alt=media&amp;token=86b8dbb1-e432-4541-b89e-51f2d2701223" alt=""><figcaption></figcaption></figure></div>
Open a model via D5 Launcher, it is locked by default. Import a model when a scene file is already opened, it is unlocked by default.&#x20;
## The model is locked in Object list&#x20;
Selecting the material directly in the scene allows you to edit the material.&#x20;
## The model is unlocked in Object list&#x20;
We need to use the Material Picker to select material.
<div align="left"><figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FML5Wnb9LxN4S99X37oBk%2Fimage.png?alt=media&amp;token=3f6c0d3f-6bc9-4a72-9fdd-7b87945a9606" alt=""><figcaption></figcaption></figure></div>
## Material Picker&#x20;
After selecting the Material Picker (shortcut key **i**) to activate it, you can continuously select the materials of any model in the scene, instead of exiting the material tool state immediately after selecting.&#x20;
## Material Penetration&#x20;
While the Material Picker is active, press the **"Alt"** key to penetrate the material and select the inner layer material.&#x20;
* Up to 2 layers of material penetration are supported.
