> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/user-guide/widget/how-to-use-advanced-video-rendering-widget.md).
# How to use Advanced Video Rendering Widget?
Key words: Widget | Advanced Video Rendering
D5 Widget is a customized extension module of D5 Render, aiming to provide advanced features while keeping the simplicity.&#x20;
Go to Menu > Preference > Widget, and you can check what you installed, switch on/off with one click to manage your widgets.
<figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FlnDhBP0pqGREPhHjvqt7%2Fimage.png?alt=media&amp;token=f1293f0e-c406-4d46-8f58-424aa9eb84f5" alt=""><figcaption><p>Advanced Video Rendering</p></figcaption></figure>
#### Video Rendering Parameters
After enabling Advanced Video Rendering, you can choose .mp4 or .avi format output in video mode, and it supports 480P, 720P, 1080P, 2K, 4K resolution for selection.
<figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FN8QOXwN6gQnNr502hbrG%2Fimage.png?alt=media&amp;token=c070377b-b0ec-40c7-89c1-87f46e230f27" alt=""><figcaption><p>Format</p></figcaption></figure>
#### Sequence
<figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FAOgDfeQURpgoe4V4VlMH%2Fimage.png?alt=media&amp;token=679a0f39-c1ac-4afc-9bbc-237ea2efa73e" alt=""><figcaption><p>Sequence</p></figcaption></figure>
Select the Sequence option in the lower right corner of the video rendering mode. Sequence frame supports to choose to export .png / .exr format images, and supports 480P, 720P, 1080P, 2K, 4K definition selection. Check the Channels option and check the desired Channels for rendering in the Settings column to the right of the Channels option, the Channels will be exported for post-processing at the same time as the exported image.
* Sky Mask
* Material ID
* AO
* Reflection
* Z Depth
* Transparent
> Sequence frame rendering is not a piece of video, it is a series of images that need to be processed in post-processing software, and .exr format image files are large, please make sure you have enough disk space.
<br>
