Re-linking File Process Introduction
If you change the path or name of the model file, you can update the D5 project using the re-linking function, ensuring that previous lighting and material settings are preserved. This process is compatible with SU/SketchUp and 3dsMax real-time plug-ins.
  • Data synchronisation after model renaming/path changes
  • Avoid duplicate light overlays
  • Preserve historical material parameters
  • Inheritance of model attributes
Workflow
Method 1: Models linked to .drs before
Scenario: The model has been linked to a D5 project, but the local storage path or name has been altered.
Operating Steps:
Activate Connection
  1. Click the ‘Connect to D5 Render’ button in the DCC plug-in.
  2. Select the ‘Sync local Project’ mode in the pop-up window.
Step 1
Select the model to replace
Tick the target model to be replaced in the popup window. (D5 materials will be inherited after replacement)
Step 2
Click ‘Replace and link’ to complete the synchronisation.
Method 2: Open .drs and the modeling file together
Scenario: need to update both the model file and the associated project at the same time
Workflow:
  1. Open the D5 project file (.drs) and the modified model file at the same time.
  2. Click the ‘Connect to D5 Render’ button in the DCC plug-in.
Step 1
  1. Select the corresponding model in the Replacement pop-up window.
  2. Tick the ‘’Light‘’ / ‘’Material‘’ options as required.
  3. Click ‘Replace and link’ to complete the synchronisation.
Step 2
Replace and link logic
Option Description:
  • Tick ‘’Light‘’: Replace the light group with the same ID (historical parameters are preserved)
  • Tick ‘Material’: Replace materials with same names (historical parameters are preserved).
FAQs
Q1: Why does the DCC prompts "Please retry after exit rendering mode or finish the rendering within D5 Render"?
A:
The general situation is: after entering the picture/video mode in D5, and then performing the increase or decrease model operation in DCC and transmitting new data (real-time update or manual update) to D5, this error will occur.
In this case, exit the picture/video mode, and then re-associate the synchronization.
Last updated
