> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/user-guide/material/what-are-the-material-tools-what-are-they-used-for.md).
# What are the material tools? What are they used for?
<div align="left"><figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FOFjHf3XTYEQvJni8RNtx%2Ftool.jpg?alt=media&amp;token=58530afe-8253-4ce7-8317-383962782b4e" alt=""><figcaption></figcaption></figure></div>
## Duplicate
Duplicate the currently selected material parameters and assign them to other model surfaces.
## Add to local
Add the currently selected material to the local library. You can find the saved material in the "Material" drop-down menu in the "Library" > "Local" tab of the navigation bar.
## Batch Import PBR Textures
<div align="left"><figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FyXhzN6awYmRHMbqbwjHn%2FPBR.jpg?alt=media&amp;token=d3a11af8-bd28-4da2-9e6f-ce0b4ef6b9d5" alt=""><figcaption></figcaption></figure></div>
In the texture editing panel, click the "Import" button, you can select multiple PBR textures in the folder with one click to import them automatically.
{% hint style="info" %}
The PBR material system contains two sets of workflows : the metallic/roughness system and the specularity/glossiness system, which <mark style="background-color:purple;">D5 supports belongs to the metallic/roughness workflow</mark>.&#x20;
The texture imported by the user should **conform to the suffix naming rules of this workflow** in order to correctly identify the material effect.&#x20;
For more details, please refer to:[What is the correct naming convention when importing PBR maps with one click?](https://docs.d5render.com/user-guide/material/what-is-the-correct-naming-convention-when-importing-pbr-maps-with-one-click)
{% endhint %}
## Reset
Restores the material parameters to their initial state (the parameters that existed when the project file was just opened or when the material was assigned to the model surface).
