How to use AI Make Seamless?
Integrates AI Inpainting to train the model for construction tasks. AI will specify a border of pixels around texture boundaries and transform the primary framework of the model to seamlessly merge the textures.
Added 'Make Seamless' to the AI section near the Base Color Map slot, which will remove seams between base color map textures for a consistent and natural effect.
Supports removing seams either vertically or horizontally to achieve the desired effect. Undo supported by Ctrl+Z.
Note: A Base Color Map is required to activate this feature.
Last updated
