> For the complete documentation index, see [llms.txt](https://docs.d5render.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.d5render.com/getting-started/d5-workflow/interface-shortcuts-camera.md).
# Interface, Shortcuts, Camera
> Project inspiration in this doc: Koala Heaven
> Architect: Mart Studio (<https://www.martstudio.de/> )
> Visualization: LINK
D5 Render provides a real-time rendering viewport and an intuitive user interface.
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXcFz3p8hec8B9WS-6QUt23T3UFDJGDWXk23zlBx5eWd-vkWRNHazkrBU4eWFQX72ACa3fXO_7Cr-_gtqkpao8ZcJvEhDe2uBFbASUp3tHNgXZh5ERaLC10K8woYwyHCBzDvAwrZ?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
## Toolbar and Shortcuts
The top toolbar provides the most commonly used features.
### Left half of the top toolbar:
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXe6UBQphkccR8wv0ChGTP-RG15CQM2arWjucNTHjf68yR0BRfsQRgXoBDrpECw5O3mnoz2XuUbV5w7xdDVjbj7qAx75FsVMoqUxbaVTyKfGeKU0KtbzvAY7CzfvWQ7bgPP-wwPx?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
“Menu” includes general settings.
“Model Import” provides a direct import option for .skp / .fbx / .3dm / .abc / .d5a files.
“Asset Library” includes high-quality models, materials, particles, HDRIs, vegetation scatter templates, and terrain templates.
“Text to 3D” utilizes AI to generate 3d models based on your prompts.
“D5 Studio” is a cloud workspace to store presets for environment, effect, scatter, brush, and path.
D5 Render also has multiple advanced features in **Menu > Preference > Widget**, including section tools, stage lights, SR rendering, and VR.
<figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FugiFzed1chsPcULDYNST%2Fimage.png?alt=media&amp;token=1c95bc57-80cb-4986-862b-e127f9edbe2a" alt=""><figcaption></figcaption></figure>
### Shortcuts
You can adjust the interface language and review **shortcuts** in **Menu > Preference**.
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXdncJk7SL5uG-Ln3XyrXKysy-yVhBpyMfhunYgI3XVdl3vDQkAzIzpC3RwK2X8YuJ6VWc9OSDkmYOsyHx0KKjWxUCxT8K7nT_osMkh7VkhGPJ93b4LzABMhTB1ZRP_VEBgZG-0_?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt="" width="563"><figcaption></figcaption></figure>
We also provide **shortcut hints** at the bottom of the viewport, allowing you to conveniently check the shortcuts while operating.
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXe23fEo1foQPtlrsXDLQRvbMINuGmu0Tm1VCTdPhA3JojQNZyZB6w5265Wzi2i1hBdDtGi956MLzRY9ArjMfvk5e3KBE5WXIIelNC1tZnNoBHsjoPFPWunl8Z-i22y2_5AUC2g?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
#### **Commonly Used Shortcuts:**
<figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FAsQlOadYL7JwhjwSTyh7%2F4ed2433e72f93d8186729ec934bdb4b5.png?alt=media&amp;token=bd3ef591-064f-484d-a353-14423413cf67" alt=""><figcaption></figcaption></figure>
<figure><img src="https://3611830798-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2F-MjbN1iGmN_HBnj_fyU9%2Fuploads%2FVjaUo1nxbXJKV9qgTRlp%2F2874706c3fb29560a594f996d20bf531.png?alt=media&amp;token=6c1b7d3b-8a2e-4910-bf5a-f7f09f3d8fa3" alt=""><figcaption></figcaption></figure>
### Middle part of the top toolbar:
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXdmhTeTDJ2tAoHLJtqzetXJpd7QhGrgTWiXiE7sdvZ6HvGCjuGMI-tIUrOhuHi1UGj6c0NYJZO4wHogVA94D2y_45rFp3AcwT6lX7ZH3whvPYmTVGD6r7iB018C1Tz0zYGQJRcr?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
“Light source” provides an array of artificial light sources.
“Path tool” works wonders when you have to arrange characters, plants, or vehicles on a straight or curved line.
“Plant tools” is a tool kit to efficiently add plants.
“Add particles” enables you to add animated particles such as birds, fire, and streams.
“Advanced camera” supports fixing the camera at a specific angle in the PiP window when you move around in the viewport. [Explore more camera settings >](/getting-started/d5-workflow/interface-shortcuts-camera.md)
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXdFdNShH5JkTzIuH8JnuuRuzGTIHXUGu2xV1_aEye5temQTXk9drWZErFCeGuVLsyrUD2w1rb9CIHzDh9y2u2tCDx_3j2sjDfALMDjBu9CkKtphkuzJIbe7ePGfIU5yQ5Ykg856?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
“Section plane or cube” enables you to section a model and review its inside structure.
&#x20;“Scatter” is a procedural plant scattering tool. You can effortlessly create delicate landscape design using this feature.&#x20;
“Terrain” system allows you to manually sculpt terrains or rapidly generate terrains from built-in templates.
### Right half of the top toolbar:
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXcpftOYnj4pv5INmoLmsfG9fRAJzCpO074XXuKkP0FNLLl2hfGyHJWJdAX-49qj3Qm1SJ417DCedhywuV8Qo8ijy-fgNzMXt5S0HpytNJdUErf1Vezzpbyq5UsQkjT0KRRTNVfB?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
The right half of the top toolbar provides features relevant with rendering outputs.&#x20;
You can export virtual tours, panoramas for VR, image, and animation. D5 supports adding output tasks to the render queue for batch rendering.
[How to export virtual tours >](https://www.d5render.com/posts/virtual-tour-d5-render)
[How to export images and animations >](/getting-started/d5-workflow/image-animation-output.md)
You can also post-process rendered images using the built-in [Post-Ai tool](/getting-started/d5-workflow/ai-features.md).
## Camera
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXdGFqwkur54QpvlXlK7u7glK0NU9R5UDzdjtt1kxr-e5J1l4iYPCqQuCOw52SuFcGedOGYezNG6qRYpAvYNshhYXcuQJyjM9Y-unHu96LDR-PPFSrGLc8Oit9DoIfsplXsajU0?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
You can click the camera icon nestled within each scene to activate the relevant camera.&#x20;
It enables you to set exposure, perspective mode, aspect ratio, focal length, camera clipping, and many other elements.
You can fix a PiP window in the bottom right corner to conveniently check the adjustments.
<figure><img src="https://lh7-rt.googleusercontent.com/docsz/AD_4nXc75hZY55hPC7dXPlvjnKVKGEZbajoqZn8VCRu-HWBZSMbzL2NH4cDUP73nBM64692HEcBLHYLnOZZoiCX2epOkEL6eJZmpYFMj8YO6b8gsVDYaTtLUMTbw-WlDLRqrNiYkc0sz?key=Fj3gEvh4f7dQWs61CsH4SzuA" alt=""><figcaption></figcaption></figure>
