# Page Not Found
The URL `learn-more/how-to-deploy-team-library-and-manage-team-assets/how-to-set-up-windows-shared-drive` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [How to set up Windows shared drive?](https://docs.d5render.com/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets/how-to-set-up-windows-shared-drive.md)
- [How to create a NAS shared folder?](https://docs.d5render.com/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets/how-to-create-a-nas-shared-folder.md)
- [Cloud Asset Management](https://docs.d5render.com/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets/cloud-asset-management.md)
- [Team Library Deployment](https://docs.d5render.com/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets/team-library-deployment.md)
- [How to deploy team library and manage team assets](https://docs.d5render.com/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets.md)
GET https://docs.d5render.com/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets/how-to-set-up-windows-shared-drive.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/instruction-for-d5-for-teams/how-to-deploy-team-library-and-manage-team-assets/how-to-set-up-windows-shared-drive.md`).
