# Page Not Found
The URL `workflow/general-questions/how-to-install-plugins-through-the-command-line` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [How to install plugins?](https://docs.d5render.com/workflow/general-questions/how-to-install-plugins.md)
- [How to uninstall plugins?](https://docs.d5render.com/workflow/general-questions/how-to-uninstall-plugins.md)
- [Why does it prompt "Could not reach server (timeout)" during syncing?](https://docs.d5render.com/workflow/general-questions/why-does-it-prompt-could-not-reach-server-timeout-during-syncing.md)
- [Re-linking File Process Introduction](https://docs.d5render.com/workflow/general-questions/re-linking-file-process-introduction.md)
- [Why does the modelling software show a different orientation compared to the top view in D5?](https://docs.d5render.com/workflow/general-questions/why-does-the-modelling-software-show-a-different-orientation-compared-to-the-top-view-in-d5.md)
GET https://docs.d5render.com/workflow/general-questions/how-to-install-plugins.md?ask=<question>&goal=<end_goal>
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/workflow/general-questions/how-to-install-plugins.md`).
