# Page Not Found
The URL `workflow/general-questions/why-doesnt-the-model-show-up-when-imported-directly-into-d5` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
- [Why does the modelling software show a different orientation compared to the top view in D5?](https://docs.d5render.com/workflow/general-questions/why-does-the-modelling-software-show-a-different-orientation-compared-to-the-top-view-in-d5.md)
- [Why does it prompt "Could not reach server (timeout)" during syncing?](https://docs.d5render.com/workflow/general-questions/why-does-it-prompt-could-not-reach-server-timeout-during-syncing.md)
- [Why the .d5a file with group structure info could not use align/sync coordinates?](https://docs.d5render.com/workflow/general-questions/why-the-.d5a-file-with-group-structure-info-could-not-use-align-sync-coordinates.md)
- [Launching D5 from the D5 converter gives the error "default error".](https://docs.d5render.com/workflow/general-questions/launching-d5-from-the-d5-converter-gives-the-error-default-error-..md)
- [Re-linking File Process Introduction](https://docs.d5render.com/workflow/general-questions/re-linking-file-process-introduction.md)
Perform an HTTP GET request on the documentation index with the `ask` parameter:
GET https://docs.d5render.com/workflow/general-questions/why-does-the-modelling-software-show-a-different-orientation-compared-to-the-top-view-in-d5.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/workflow/general-questions/why-does-the-modelling-software-show-a-different-orientation-compared-to-the-top-view-in-d5.md`).
