Why "Reload" shows gray when using the D5 Converter to sync the models?
Key words: Import model | File format | Workflow
You can only use the "reload" feature when you import the models directly.
If the models synced to D5 through the D5 Converter plugin need to be reload, you can use the sync feature of the plugin.
If you use the D5 Converter plugin to export .d5a files and import them to D5 (import directly) without changing their file path, you can use the reload feature. If you have changed the path the updated models, you need to use the "Replace from the local folder" and manually select the model files path during update
PreviousWhy is it that in the modeling software/D5 the close textures are clearer and the farther textures οΌNextPlease install the latest version of D5 Render, if you have already installed the latest version.
Last updated
